Ive got some hope pro 2 hubd currently 15mm front and 135x10 bolt through rear. Can anybody tell me what i need to convert to 20mm front and standard qr rear please
Is this for a project build?
Have you even looked at the hope adaptors?
Hope 20mm Adapter for the ProII
Rear could be end caps, check the link for a part number ProII have the narrower internals over the later Evo stuff
Front hubs are the same. Rears differ between pro 2 and pro 2 evo. I know this makes a difference for 12mm on the pro 2, it needs a new axle. I'm not sure what's needed for the 10mm though. I've a feeling it would just be end caps though.
Bruneep i just seem to be getting lost in the minefield of pro 2 and pro2 evo hubs. Just wanted to make sure i was ordering the right bits!
Confusing isn't it!
You'll need a 20mm front adaptor doesn't matter whether evo or not.
I don't know about rear bolt thru, won't it work in a standard 135 frame? I'd be tempted to leave if so as you'll need a new axle and end caps and they are tricky to source otherwise
If you want to leave it 10mm bolt through and us it in a normal QR frame you need something like this:
http://www.superstarcomponents.com/en/ultralight-alloy-10mm-rear-qr-through-axle.htm
Rear [url= https://www.jejamescycles.co.uk/hope-pro-2-rear-qr-hub-conversion-kit-id57017.html ]https://www.jejamescycles.co.uk/hope-pro-2-rear-qr-hub-conversion-kit-id57017.html[/url]
or stick a wtd ad up
For the rear a new axle the q/r version, and the end caps. Will look numbers up if you want.
Front just the 20mm adaptops and circlips for each side.
i have a spare set of the 20mm adapters you can have for a few quid if you want? used, but in perfect nick...
Xherbivorex yes please. Emails in profile if you can get in touch please
