I have one hub which has 20mm and i want to swap to a 15mm. what do i need?
thanks
You just need to pull the 20mm adaptors out and pop some 15mm ones in. About £15 from CRC last time I looked.
some for sale in the classifieds
http://singletrackmag.com/forum/topic/gigantic-clearout-of-new-and-used-itemsforks-etc-40-items
in there, £10
Just remember when you come to remove the 20mm ones they are held in with cir-clips and the 15mm ones just push in like the QR ones.
there is a good video you can watch over on the hopetech website if you are unshure.
Just get a small screwdriver and lift the end of the circlip out (the end that is sort of angled/pointed) and then just peel it out. The 20mm adapters then just fall off. The 15mm adapters then just push in as said above. Should do it in under 2 minutes.
many thanks guys for your help,
cheers
