I'm helping my friend put together a gravel bike and his wheels use Hope Pro 5 hubs, which I'm familiar with, but with centrelock brakes I'm not.
Hope sell lockrings with internal or external tightening options - apart from the different tools to tighten, is there any difference? Any advice based on experiences, etc?Â
(The discs are 160mm Shimano Ice Techs, XTR I think, if that makes a difference)
Need external for a 15mm front axle, rear can be either
Ah, perfect. Many thanks!
What STR said.
You do need to get them from the hub manufacturer as there are (at least) 2 different ways the external ones can have the 'external' lockrings. So if you're tempted away from Hope, check the thread specifications.
Â
Â
Yep, understood. The Hope hubs have the thread inside the hub.Â
Â
One thing I have just thought though, I'm pretty sure the hubs in question are actually 12mm front thru axle... would that sound right for the carbon forks you'd get with a Sonder Camino Ti?
Yes that's correct
Thank you
