Having a moment and confused myself about the width of a Hope Pro 4 rear hub.
The standard hub is 135mm right?? then you add various end caps to get up to a max fitment of 142mm.
I guess the question is - If I remove the current end caps from the 142mm set up and replace them with QR end caps, will it then fit a 135mm qr fitment frame??
Carlos
#toomuchsunandalcoholovertheweekend
Posted : 02/07/2018 9:17 am
So long as it isn't boost, yes
Posted : 02/07/2018 9:19 am
yes, it's just an end cap swap.
Posted : 02/07/2018 9:20 am
Cheers guys.
Posted : 02/07/2018 9:34 am
