Hi all
I have just bought a Hope fortus 30 rear wheel with a Pro 4 hub and I want to convert it from 135mm QR to 12x142mm. On the Hope site it says the wheels are supplied with 135mm QR and 12x142mm conversions but there are no other parts in the box so is it just a case of pulling off the QR end caps? Hope are closed until 2nd Jan otherwise I would give them a ring.
Thanks
You need the 142x12mm end caps on after taking off the qr ones
Thanks. It looks like they forgot to include them with the wheels then which is a shame as I'll have to wait until the new year to use them.
Should come with extra adapters, the ones attached just pull off but can be hard to get off when new, especially QR ones, I used some rubber wrapped mole grips. The shop you bought from should sort it after boxing day.
