Hope Pro 3 - Moveme...
[Closed] Hope Pro 3 - Movement in front wheel
6 Users
Bearings all seem fine, running silky smooth on the bike. Issue is that there is play when the wheel is in the fork, but I can't feel any play when the wheel isn't in the fork
Causes a similar vibration to riding without sufficient spacers in the headset..
Thanks in advance
Posted : 28/06/2010 6:14 pm
Tried another wheel in the fork? Does it also have movement? At least you know then if it's really the Pro3 or actually the fork's moving.
Posted : 28/06/2010 6:20 pm
Tried another wheel, no vibration at all. Deffo the Pro3
Posted : 28/06/2010 6:22 pm
some Pro IIs were known to have play with Maxle 20mm bol thrus, never seen an explanation other than the obvious (differences in tolerances) or any solution.
Posted : 28/06/2010 6:27 pm
This a a road bike..thanks though.
Posted : 28/06/2010 6:33 pm
I know this is a bit obvious and basic but have you tried a different quick release? Hope q/r don't have the best record.
It's one of the reasons I'll switch to 15mm bolt throughs on mtb in future.
Posted : 28/06/2010 6:43 pm
Yup, tried a different quick release. Same issue. Hmmm
Posted : 28/06/2010 7:35 pm
The bearings in my front pro3 weren't seated properly when I got them, caused some vibration, although out of the bike all ran smooth. A couple of clowts with a mallet and bearing tool sorted it in seconds...
Posted : 28/06/2010 7:41 pm
If it's a Pro3 road hub try tightening the 2 part axle up, the 2 halves screw together and can sometimes come undone.
Posted : 28/06/2010 8:00 pm
It is a Pro3 road yeah. I take it those will be the two allen key bolts at either end of the hub? If so I've already had those off to check the bearings along with a retighten.
thanks
Posted : 28/06/2010 8:04 pm
