I'm rather confused 😳
What bolt through options do I have with Hope Pro 2 rear hubs and standard rear dropouts?
10mm
Stiggy - Member
10mm
Is that a random dimension or does it mean something?
I think that's the diameter of the bolt. I think you can get bolt through to take one of the 10mm QRs like Superstar and others do; or bolt-up where the ends of the axle are threaded to take 10mm allen bolts at each end.
12mm maxle or bolt through
10mm which i believe is a bolt through q/r axle
and q/r
i think it's also possible to get a hub that takes two treaded bolts, no idea what that is.
hub is also available in 150mm width.
One of [url= http://www.chainreactioncycles.com/Models.aspx?ModelID=11825 ]these[/url] ?
The bolt-in seems to be out of stock everywhere, I had mine backordered with one shop, cancelled the order and now it's backordered with someone else 😛
Sorry I haven't got back, yup kenshields that's it : )
