Whats the easiest way of getting my 10 speed XT cassette, which needs replaced, off the alloy freehub given that it's going to be a bit 'stuck on' in usual Hope fashion. Would rather not pop freehub as dont have reseating tool for seal to hand
I put the wheel down on the floor with the cassette side facing down, with the end of the axle adapter thing on the floor, so the freehub doesn't pop off. I then put a (very) blunt screwdriver with some cloth wrapped around it through the spokes and onto the back of the cassette. Give it a few sharp knocks with a hammer and it should come off.
Try to get hold of a cassette cogs mounted on an aluminium spider, which will stop this problem in the future.
thanks for that, will give it a go. XT cassette usually ok spider wise, but last one I did was a little dug into freehub body
Use a second chain whip to turn the stuck sprockets anti clockwise out of the notches they created for themselves!
It should then come apart easily.
If it's been used a bit the "seal" will be slacker than a slack thing! Should just pop back in place or use a plastic tyre lever to give it a nudge. It's a pretty rubbish seal, other seals are offended by the association.
I lay wheel on floor, wrap a rag around the base of the cassette, and with flat blade screw driver and hammer, tap the individual cassette cogs to get them to unseat from the notches they've cut into the freehub body. Usually one at a time, until you reach the spider mounted cogs, this should come straight off.
You can dress the body with a steel file to take the burrs off, and refit the cassette with some anti-seize, but it does not really help, and I've suffered from the gouges in the body getting worse, clicking and creaking noises under power and even shifting dwell as the cogs have ended up out of alignment
The only solution is to swap out the alloy body for the steel body, after the 3rd one went on my road bike, Hope gave me a steel body FOC.
I use a chainwhip to stop the cassette from rotating while giving the rest an anti-clockwise bash with a rubber mallet.
Works every time, but don't use your best rubber mallet!
cheers all, some great fixes in there, thanks
I'm new to this malaise. Having stripped my wheel the other day I was quite alarmed when, instead of just the cassette coming off, the whole freehub body - with cassette still attached - came off! What is this badly engineered pile of carp?
Cheapo Shimano freehubs played perfectly well with a variety of cassettes fitted to them, so what gives with the Pro 2 Evo?
So anyway, what tips for removing a cassette off a now unattached freehub body?
What I do is screw the locking ring back on and use a chain whip on each individual cog to free them from being embedded, until the last that are all together
OK I'll try that thanks
The axle will snap soon as well. HTH
Or it might be fine for seven years+, one or the other. HTH.
Place cassette and freehub body bottom down on an open vice so that cassette is supported but freehub is not. Nice lu!mp of wood on lip of freehub and whack with mallet. Jiggling with a pair of chain whips also helps.
PS removed springs and pawls before commencing whacking...
I could be mistaken but I'm pretty sure the seal will stay in place if you rotate the freewheel whilst pulling it out. Then just take the sprockets off one by one using any of the methods suggested above (with better access to them as there's no wheel in the way).
It's then probably a good time to clean up and regrease the freewheel mechanism.
