Hope Pro 2 Evo fron...
[Closed] Hope Pro 2 Evo front bearing change
11 Users
Bought a new set of Hope bearings for the front hub. As you would expect, they feel nice & smooth. Drifted the old ones out & put the new ones in (using a 24mm socket) & they feel terrible. Really rough & notchy.
Figured I'd damaged them when putting them in, so knocked them out again and they feel nice and smooth. All roughness has gone.
So rough & notchy when in the hub, silky smooth when not. What am I doing wrong?
Posted : 23/02/2013 9:02 am
get the proper hope tools?
Posted : 23/02/2013 9:17 am
Not sure if the EVO is the same, but I forgot to put the spacer tube in an older Pro2 front once, & it felt rough but was ok once I'd spotted it on the bench. 😳
Posted : 23/02/2013 9:23 am
 br
+1 proper tools
Posted : 23/02/2013 9:29 am
Proper tools now acquired & tried again. One side went in fine but feels exactly the same (rough in, smooth out). The other side won't even go in straight & has gouged the race. Have I borked the hub shell?
Posted : 06/03/2013 8:37 pm
Proper hope bearings or cheap ones? If damaged the tools make no difference, once damage in the bin with them. Bearings can feel smooth when buggered, then a tiny bit of side pressure and the notchyness appears. Remember there is a spacer in the front hub that will produce this a very slight side load.
Do you have any pics of the damage in the hub?
Posted : 06/03/2013 9:03 pm
I need to change the front bearings on my Pro 2 hub. Is it a case of Hope ones are best our has anyone found any other good qaulity ones?
Posted : 24/04/2013 7:22 pm
I'm sure the hope tools are very good but for the amount of use you will get from them they're expensive. A length of threaded rod, two nuts and two big washers cost me £1-80 from the local hardware store and used like a kind of sideways on headset press did the job brilliantly.
Posted : 24/04/2013 7:38 pm
 br
Doesn't the evo run different sized bearings in the front than the older Pro 2?
Posted : 24/04/2013 8:21 pm
Nope, the same size bearing for both hubs (6804/61804)
Posted : 24/04/2013 8:42 pm
Just the rear
+1 the proper tools - mine have saved me ££ over going to the bike shoppe
Posted : 24/04/2013 9:01 pm
I found the tolerance on my pro 3 rear hub was too tight for the bearings, so by pressing them in, they went tight and notchy. Took me a few goes, but wet and dry paper, I cleaned out the anodising and a few thou of surface material and pressed them in and they went in nice and smooth and no notchiness. Took about 3 or 4 goes of in and out to get it right.I used a length of studded bar and nuts and big washers, not a Hope tool in site and the bearings went in fine.
Posted : 24/04/2013 9:11 pm
What grease you lot using on the pawls & springs in the rear hub?
Posted : 24/04/2013 9:21 pm
I use a smear of silkolene pro and seems great for mine. Winter might make it a bit thick, but wont know for a while hopefully !
Posted : 24/04/2013 9:24 pm
Katec on the bay do good bearings.
Tools too.
Posted : 24/04/2013 9:31 pm
