Hope pro 2 evo bear...
[Closed] Hope pro 2 evo bearing tools
7 Users
 rhid
Does anyone sell a complete kit for removing and reinstalling bearings on a hope pro 2 evo rear hub?
I am struggling to find anything as internet on my phone is poop.
Can someone please point me in the right direction?
Posted : 30/08/2016 8:57 am
Try 18bikes
Posted : 30/08/2016 8:58 am
Not much help but I did mine very successfully with a hammer and a round bit of tube, its very easy.
Posted : 30/08/2016 8:59 am
I know some folks prefer the proper tools which is fair enough, but do you know you can do it all with a socket set? Not as foolproof but works just as well as long as you're halfway competent.
Posted : 30/08/2016 9:00 am
 rhid
Competent you say...
I'm fine getting bearings innit what's the best way to get them out?
Posted : 30/08/2016 9:23 am
best way I've found is to ask your LBS to do it all.
Posted : 30/08/2016 10:19 am
rhid - Member
Your assortment of hammers and pokey things. I recommend That Centrepunch I Bent Somehow for getting the first bearing out in each set, then the Front Axle From A Suzuki SV650 for the other one
Posted : 30/08/2016 10:36 am
 rhid
I have all that lying around so it should be no probs.
The bearings where Changed but the lbs on Friday. Too my bike to another stiniog rode 2 runs before the wheel developed play again.
Figure it's cheaper if I do it myself from now on!
Posted : 30/08/2016 10:52 am
The bearings should always last better than that, something wrong here... Either a fitting error or they've used some cheap crap bearings. Either way I'd be picking it up with the shop too.
But it's definitely handy to be set up to do it yourself, I found a grumbly bearing in my main bike's front wheel last night, 5 minutes later it's sorted, it's not so much money as just not having the hassle of going to a shop and having downtime with the bike.
Posted : 30/08/2016 10:55 am
 PJay
I bought from these guys on ebay - [url= http://www.ebay.co.uk/itm/Hope-Pro-2-EVO-Hub-Tool-Kit-/161987006180?hash=item25b72d8ee4 ]www.ebay.co.uk/itm/Hope-Pro-2-EVO-Hub-Tool-Kit-/161987006180?hash=item25b72d8ee4[/url] which I thought was good value and it all turned up promptly.
Oddly this kit doesn't include the hub support tool (which is a bit cheaper via CRC).
Posted : 30/08/2016 3:15 pm
The hub support has always been a separate item.
Posted : 30/08/2016 3:22 pm
