Hope Pro 2 axle opt...
[Closed] Hope Pro 2 axle options
10 Users
So it turns out I'm way too rad (or clumsy) for my Hope axle. Spent the ride dropping chains with no obvious cause (1x with a NW chainring so should be fine), got home and quickly found a possible cause. My Hope Pro 2 rear axle has snapped. Quite pleased to make it home now (although I was of course only walking distance away). I suspect my weight, not very delicate landing technique and riding a hardtail coupled with an old hub has caused the demise. Looking at the axle it is pretty thin. What are the upgrade options? Don't mind a little extra weight for some extra beefiness. Its a 135x10 QR but happy to go to bolt through it that is an option. Or will just getting an axle that isn't 10 years old be enough?
Posted : 27/04/2020 1:49 pm
 goby
Yep done that myself, just replaced the axle for another and posted a wanted on here.
Posted : 27/04/2020 1:58 pm
If it is the Pro 2 and not the Pro 2 Evo I have one that I'm not using. For a sensible offer it's yours.
Posted : 27/04/2020 1:59 pm
See if it's worth going to the Evo axle setup while you're at it.
I did my pro 2 so that I could fit an XD freehub. Maybe the axle is stronger.
Posted : 27/04/2020 2:00 pm
I had a Pro2 alloy 142x12mm axle snap. Replaced it with a steel one and no issues.
Other option is to change all the bearings to those in the Pro2 Evo and use the Evo axle kit. Thicker walled alloy.
Posted : 27/04/2020 2:01 pm
Thanks all. I have stripped it down. Pretty unimpressed with the stress riser corner where it snapped. Think I'll be tempted to go for steel if that is an option. How do I tell if it is EVO? It has 6903 bearings which are 17mm, a quick google suggests that makes it EVO but there is nothing about that written on the shell.
[url= https://i.ibb.co/19sbN7t/hope-axle.jp g" target="_blank">https://i.ibb.co/19sbN7t/hope-axle.jp g"/> [/img][/url]
[url= https://i.ibb.co/fqKpQkH/hope-hub.jp g" target="_blank">https://i.ibb.co/fqKpQkH/hope-hub.jp g"/> [/img][/url]
Posted : 27/04/2020 2:37 pm
The bolt in option is steel
Posted : 27/04/2020 2:39 pm
That's deffo a Pro2 hub
Posted : 27/04/2020 3:14 pm
It is but the hub shells are identical- you can swap Evo axle, bearings and freehub in. Not cheap.
The Pro 2 12mm is shite- basically the hub was never designed for it, then when they decided to make a 12mm version they just used the same axle design with a bigger hole, and it's too thin. And as you say they stuck a stress riser in it just to make sure it broke. The last time I broke one, Hope sent me two replacements, "for next time it happens". But refused to even do me a discount on the Evo parts 🙁
Posted : 27/04/2020 3:21 pm
There's a chance I still have a Pro2 135 QR axle in my garage, PM if interested.
Posted : 27/04/2020 4:21 pm
I have a few spare pro 2 rear axles too. If you still need one please email me.
Pretty sure I have the 135 bolt in version. I don’t think they snap.
flatpedalthunder(at)gmail(DOT)com
Posted : 28/04/2020 10:20 am
The great thing about the Pro 2 hub is the bolt up and quick release are interchangeable as others have said, so no need to rebuild the wheel... didn't remember the bolt up is steel but that's a good thing. I did this on my Karate Monkey a few years back and have had no issues...
Posted : 28/04/2020 5:27 pm
