Hope pads prone to ...
Hope pads prone to contamination?
4 Users
Hi,
I use hope RX4 brakes on my gravel bikes. Have had them for around a year or two.
My rear pads have always been replaced as they gotten contaminated. I go through probably 3 or 4 sets a year. I have never worn a set out on the rear.
Never had this issues when using ahimano pads previously.
Anyone finding the same or just me?
Posted : 01/11/2022 6:10 am
Got the RX4 on the rear of my road bike after the Shimano caliper seals failed (front still has Shimano) - so far so good - not had any get contaminated so far.
Posted : 01/11/2022 6:16 am
I wonder if it's wax based lubes?
I switched to Squirt around the same time as changing brakes. And now use rock n roll gold.
Wax particles getting tossed off the drivetrain being picked up by the brakes?
Far fetched? 😄
Posted : 01/11/2022 6:41 am
Its not an issue I have using hope brakes and putoline. I wonder if they are cold polished not contaminated. Hopes pads seem to need more bedding in and be prone to cold polishing if only ever used gently. I think hopes use more adherent friction and less abrasive friction than others
Posted : 01/11/2022 7:32 am
 igm
I suspect TJ may be correct. Hope brakes do seem to benefit from being worked hard.
Posted : 01/11/2022 11:42 am
