I bought some 2nd hand Hope Evo M4 brakes and unfortunately they need a rebuild to have any chance of working!
I have a problem though, how the f*** do you get these 2 pistons out?
Has anyone done this before and succeeded?
Posted : 05/10/2014 12:10 pm
You have to put all the pistons in, fill with fluid, remove pads and pump the brakes till both the inboard pistons are out, pushing in the outboard ones as you go, make sure both inboard ones are out the same distance, eventually one will pop out, the you should be able to carefully lever the other one out easily too
Posted : 05/10/2014 12:24 pm
