Hope mono 6 - Help!
[Closed] Hope mono 6 - Help!
6 Users
Hi all,
I thought one of you would know the answer to this... what size alan key do I need to remove the tiny bolts in the top of my hope mono 6 reservoir?
I went through almost 40 alan keys & none fit... It can't be 1mm, is it 1.5mm or imperial?
Thanks in advance to everyone who helps.
Posted : 23/05/2011 7:29 pm
[url= http://www.hopetech.com/webtop/modules/_repository/documents/2004Mono6-Tiexplodedview.pdf ]Which One[/url] Only M6's on the digram unless you mean on the lever, 2/3mm but can be made into screwdriver compatible
Posted : 23/05/2011 7:32 pm
Moto? They're T10 torx.
Posted : 23/05/2011 7:34 pm
thanks so far guys - it's not MOTO or 6ti just mono 6. I mean the 2 bolts that hold the top of the reservoir on. any ideas? right where it says dot 4 or 5.1. cheers...
Posted : 23/05/2011 7:38 pm
No they are not threefish - they are 2 mm on my hope M6s Its an unusual size
Posted : 23/05/2011 7:39 pm
They've only ever been either 2mm (original dome-top), 2.5mm (later flat-top) or T10 (Moto). I have a feeling that you may have a couple of rounded-out bolt heads. Could you post a picture?
Posted : 23/05/2011 7:42 pm
Moto M6 use T10 torx.
Posted : 23/05/2011 7:43 pm
thanks again, they may be 2mm yes. I know they are not rounded, I can see they are so far untouched. I know they aren't 2.5 because thats what I use on the lever to adjust the reach so I tried that already...
would like to post a picture but it's genuinely to hard for me at the minute.
Amazing that so any have already helped, thanks again everyone!!!
Posted : 23/05/2011 7:47 pm
Threefish - I have a set and just checked - its 2 mm. Its not a moto set - read the post. 2 mm on hope flat top resovoirs. - the hope mini lever
Posted : 23/05/2011 8:11 pm
What are you talking about? I said that Moto (still marked Mono on the caliper) would be T10. You said they wouldn't be; you were wrong - see picture of Moto lever as evidence.
For the Mini lever you've pictured, the dome-top bolts will be 2mm. The flat-top [b]bolts[/b] will be 2.5mm.
Posted : 23/05/2011 8:31 pm
I am answering the OPs question. He does not have a moto lever as he said . So his standard bolts will be 2 mm
You might get your naming of the bolts correct as well. Dome head or cheesehead, Dome head ones are standard.
Posted : 23/05/2011 8:35 pm
I am answering the OPs question. He does not have a moto lever.
That wasn't established, and could not be assumed, until I asked him.
You sad, sad man.
Posted : 23/05/2011 8:37 pm
Probably machine screws as well not bolts
Posted : 23/05/2011 8:39 pm
Do you ever feel embarrassed by the way you conduct yourself on here?
Posted : 23/05/2011 8:45 pm
Do you? You claim expertise you clearly do not have and are objectionable and stroppy when its pointed out.
I merely am laughing at you.
Posted : 23/05/2011 8:50 pm
Do you feel embarrassed by your conduct or not?
Posted : 23/05/2011 8:55 pm
I bought some replacement bolts in stainless steel as the originals are known to round & the new ones were 3mm hex.
Posted : 24/05/2011 7:52 am
TandemJeremy has posted the correct picture & thanks so much! 2mm it is.
Thanks for all the help & I really didn't expect this much help (or dispute).
you are a good bunch.
Posted : 24/05/2011 1:23 pm
an update for you's...
I got hold of a 2mm key & it round both straight away! I got them both out though (easily) by hammering a slightly larger torx into the hole. worked a treat.
they tightened properly too. Job done & many thanks to all. I will contact hope & upgrade the bolts to torx heads.
rob
Posted : 28/05/2011 10:02 am
Hope at some pint have used 2mm,3mm and t10 torx for the resevoir top cap screws so YOU WERE ALL RIGHT....a bit.
Posted : 28/05/2011 10:29 am
