Hope Making Rims…
[Closed] Hope Making Rims…
29 Users
So, it seems [url= http://www.pinkbike.com/news/Hope-New-Rims-Stems-and-More-Core-Bike-2014.html ]Hope are venturing into the rim market[/url] now, shall be very interested to see what others make of them once they're 'out there'.
Quite a fan of the Stans/Hope combination, so the question will be will I continue to buy off the shelf hope hoops in the future or build some myself… time will tell I guess.
Posted : 28/01/2014 11:04 am
42T rear cassette sprocket too 🙂
Posted : 28/01/2014 11:13 am
If nothing else, should be some spectacular anodised colour options. Bring on the 90s!
Wonder who's making the rims...
The 42T adaptor makes sense and I shall look forward to fitting it along with my Hope cranks. Is it compatible with the clever combined freehub/cassette thing they also are definitely about to make 😉
Posted : 28/01/2014 11:26 am
Very interesting.
Quite a few things I could go for there.
Posted : 28/01/2014 11:27 am
I like the look of the 35mm stem
Hope its not a boat anchor 😉
23mm wide enduro rims are lagging a bit behind the get-wide fad.
Posted : 28/01/2014 11:31 am
I want that stem now!
Posted : 28/01/2014 11:36 am
Wouldn't have thought so 😛
Is it 35mm long or 35mm bars?
Or both?
Posted : 28/01/2014 11:38 am
wouldn't be surprised if it's Alex Rims.
They won't be light then
Posted : 28/01/2014 11:40 am
Long.
Posted : 28/01/2014 11:42 am
42t rear sprocket sounds great, price/ availability........?
Posted : 28/01/2014 11:54 am
looks similar to this but i expect it will be a bespoke design
440g - 480g 26-700c xc rim
and thats just their own branded rim, they build for a lot of people.
Posted : 28/01/2014 11:56 am
Not much of a Hope fan boy, but I'd be interested to hear how much the 42 tooth rear cog will be and when it'll be available.
At least the rims have some subtle graphics unlike their bars!
Posted : 28/01/2014 12:02 pm
Long.
Sure? That looks like a 35mm bar clamp to me.
Posted : 28/01/2014 12:04 pm
whats with the current fad of sticking a chainring to your rear wheel ?
Posted : 28/01/2014 12:05 pm
How long do we reckon a Hope ally freehub will last with one of those 42T sprockets on, before it tears through the spines?
Posted : 28/01/2014 12:07 pm
I don't have any problem running an 18T single speed on Hope hubs, so I doubt sitting and spinning on 42T is going to cause any problem. Why do you think it would?
Posted : 28/01/2014 12:13 pm
trail_rat - Member
When you're an auld bastid like me who canna climb hills every advantage helps. One day you will find out. 😉
Posted : 28/01/2014 12:16 pm
What's with the current fad of folks trying to make stuff the taiwanese, chinese mainland beat the pants off them at ?
Posted : 28/01/2014 12:17 pm
More torque on larger sprockets, folk desperately trying to make 1x10 work won't necessarily be spinning!
Posted : 28/01/2014 12:20 pm
What bars?
Posted : 28/01/2014 12:32 pm
in my experience it's the smaller sprockets that create the damage to freehub bodies. it's not the bigger torque from larger sprockets, it's the faster accelerating smaller sprockets hitting the splines as you stomp on the pedals and the freehub pawls take time to engage.
Posted : 28/01/2014 12:52 pm
No reason why not, Alex have their own alloys for rims, make stuff for Shimano and DT among others. They have some great OE spec rims but the price puts them against 'brand' rims so they don't get used as much as they could.
Posted : 28/01/2014 1:00 pm
Alex "make" a lot of rims for many "brands", including Roval (specialized)
I have some rather nice Roval aluminium alloy 29'er rims on my 29'er, these weigh sub 500gm which is rather impressive considering their width (28mm) and that they have eyelets. They also take a big tire like a Purgatory and provide a secure tubeless conversion setup.
In 2 years of riding, I have yet to bend one, or crack the rim, unlike the many Stan's ZTR rims which I have used, which always eventually cracked around the spoke holes as they had no eyelets
Posted : 28/01/2014 1:12 pm
What bars?
[url= http://www.hopetech.com/page.aspx?itemID=SPG474 ]They bought some put last year. [/url]
Posted : 28/01/2014 1:18 pm
You mean the ones that aren't riveted together and thus more prone to moving independently...?
Whilst my Roval Controle SLs were utterly wrecked after less than 2 years, flat spotted, dented, and they needed bearings about every 10 hours of use (not exaggerating), whilst I've never had a problem with Stan's rims, including their Podium rims which were far lighter than the Rovals.
The newer Rovals do seem a lot better admittedly, but I'd still rather hand build.
Posted : 28/01/2014 1:41 pm
Have they sorted a shimano 11 speed cassette body yet?
Posted : 28/01/2014 1:42 pm
[url= http://singletrackmag.com/forum/topic/hope-bars ]Not exactly.[/url]
Posted : 28/01/2014 2:27 pm
I guess so, yes. Shimano XT ones are the ones I use.
Posted : 28/01/2014 2:40 pm
FWIW I've found my Rovals to be much softer than equivalent Stans. Probably because they divert weight into eyelets and away from the rim itself? But they're "durable" I suppose is the word, you can batter crap out of them and straighten them out and they come back for more.
Posted : 28/01/2014 3:06 pm
Even more relevant then, as the largest sprockets are held together on a carrier - hence the recommendation to use such cassettes with alu freehubs.
Posted : 28/01/2014 3:08 pm
For comparison my first 'propper' MTB had alex rims (XC19?), when they wore out I 'upgraded' to mavic 517's (the then top end v-brake rim) and they were heavier!
My Pitch had alex rims OEM, again, considerably lighter than the Mavic's I replaced them with.
Maybe not Stans light, but then they've not got eyelets, the OEM stans with eyelets are pretty much mavic weights.
Hope RS hubs are the new 11s hubs, not clear if the frehubs are compatible though, they're the new 40t ratchet ones.
Posted : 28/01/2014 3:47 pm
Rims will be a gamble for them, perhaps not worth it TBH...
TBH I'm not expecting the N/W ring or 42t sprocke to be particularly cheap (assuming they get to market this decade), happy for them to prove me wrong though...
If they can put the sprocket on the market for a reasonable price (under ~£45?) and the N/W ring at a comparable price to RF/Works/Blackspire's before the summer they'll do well, the fanboi's will see to that...
fail to get those in shops before April and they'll have missed yet another chance...
Posted : 28/01/2014 4:10 pm
is this the sign of a fractious relationship with Stans? or perhaps that Stans are expanding into the hub world?
Posted : 28/01/2014 4:17 pm
That or Hope have realised they can get their own branded rims made cheaper than they buy them from Stans, and then sell them off the back of their reputation for customer service, product quality and general all round British-ness (even though they won't be made in Britain)
Posted : 28/01/2014 4:23 pm
if shimano bring out an 11-42 (or even 40) 10speed cassette then the all these adaptors will be useless
anyone know what shimano are offering for 2014?
Posted : 28/01/2014 4:26 pm
Not sure; I'd heard a rumour that Hope Hoops bought in the States are assembled by Stan's onto Hope Hubs to save shipping costs.
Thing that might affect relationship is that Stan's are selling their carbon rims only as a wheelset with their own hubs.
Posted : 28/01/2014 4:30 pm
Just this I'd guess - much better margins and they get to spec the exact rims they want.
Posted : 28/01/2014 4:33 pm
You know Stan's already do hubs, and have done for some years.
Posted : 28/01/2014 4:35 pm
Anyone know who makes Stan's hubs, incidentally? I'd heard Novatec.
Posted : 28/01/2014 4:39 pm
I do now 🙂
Posted : 28/01/2014 4:49 pm
We spoke at length about this with Hope at the show.
Rims aren't to compete on price (it actually costs them more than Stans now they're bulk buying so many of those) - more to offer something even stiffer than the Flow EX. I'm likely to try a set, we'll see.
Narrow/wide ring is on the way to us (so they say) - so hopefully by the end of the week. £45 RRP. 32/34/36t to start, then 30t in a couple of weeks.
Posted : 28/01/2014 4:57 pm
Stans rims are made by Sun, but then I don't think Sun make their own hubs do they? IIRC at least some are Novatec
Thought it was that Sun had licensed the Stan's rim profile?
Posted : 28/01/2014 5:31 pm
Rims are made specifacally for hope by the people who make xtr rims, look really good tubeless compatable and two sizes, am and xc. Stem is 35mm long and looks pretty good. 42 cr is still a prototype and could well drop to 40 to make it work properly but it looks good. Nw chainring in 32,4 6 and there will be a 30. All looking good from hope.
Posted : 28/01/2014 5:52 pm
ratherbeintobago - Member
As I understand it both are true- Sun make the Stans rims and licence the bst for their own wheels
Posted : 28/01/2014 7:30 pm
 JoeG
Sun Rims is part of the Hayes brake company. They do Hayes, Sun Ringle, Answer, Manitou, and Wheelsmith spokes.
Posted : 28/01/2014 8:34 pm
Jesus after reading this I'm confused with who makes what for who now 🙂
Posted : 28/01/2014 8:47 pm
Posted : 28/01/2014 8:53 pm
