hope m4 poor brakin...
[Closed] hope m4 poor braking - I dropped a bollox
8 Users
we'll my brakes felt like they needed an overhaul - so I cleaned everything up - worked free the sticking pistons and rebleed the system.
however it made things much worse I couldn't lock the wheels.
After scrubbing the discs with sand paper (out on a ride) things improved. (I must have got the fluid everywhere)
but a few days later I figured I'd used old used brake fluid (from a car) I had written on the bottle used but it had rubbed off.
hopefully a re flush with new fluid will do the job!
Posted : 07/12/2011 11:36 am
 jedi
i got fluid on my pads the other week so cooked the pads for a min on my stove at herts to burn the fluid off. they now work a treat again
Posted : 07/12/2011 11:39 am
 P20
I've now got a set of contaminated pads that i stick in when i bleed brakes just in case. Then simply remove them and clean the whole thing up before putting the pads back in. It then doesn't matter if the pads get wet
Posted : 07/12/2011 11:43 am
P20's solution +1
An alternative to Jedi's solution is to drag them down a very big road hill untill they get realllllly hot.
Posted : 07/12/2011 11:52 am
I take pads out and use an avid bleed block, they also fit my hayes stroker trail calipers.
Posted : 07/12/2011 11:55 am
This has happened quite a few times to me!
+1 for baking the pads in an oven for a while as this seems to make them sweat out the fluid. Also, gently braking whilst hooning down a hill repeatedly works well too.
While baking the pads, it's often a good idea to wipe the rotors down with either an alcohol wipe or meths at a push.
Posted : 07/12/2011 11:57 am
uhmmm, you did scrub the PADS not the disks right?
To clear the crappy fluid yes should be ok.
Why do you keep old contaminated brake fluid anyway?
Posted : 07/12/2011 12:36 pm
I sanded both the pads and discs - to be honest sanding the contaminated pads did'nt work - but sanding the discs helped loads - I've not cleaned them with degreaser.
why do I keep old fluid....not sure mate.haha
Posted : 07/12/2011 12:45 pm
And Hope M4's
