Hope M/C + Guide Ca...
[Closed] Hope M/C + Guide Callipers = Killed To Death?
3 Users
So, 30 celsius yesterday and got a free bonus resistance training session with the sticky piston problem. Only way of getting home was removing the callipers at both ends and just fixing them to the frame.... I found the info on the M/C piston swap on here but I have some Hope M/C's in the bits box which might get me riding again...
So Hope M/C + SRAM Guide callipers... go or no go?
https://photos.app.goo.gl/1omzqFTEpYNs2Nzb9
https://photos.app.goo.gl/3PoRVtPUZc73mRRv9
Posted : 02/06/2019 8:54 am
if the ore of the master cylinder and stroke of it are similar then it should be fine
Posted : 02/06/2019 11:23 am
It’ll work, both use DOT fluid so no seal problems.
Issues potentially are a hose with suitable connections (faint possibility that bore/od may present problems when mating Hope fittings to existing Guide hose) and secondly as TJ suggests that until you try it you won’t know if the Hope levers move a wildly different amount of fluid.
Assuming no connection problems, be cautious until you find if you suddenly have hair trigger brakes or v-e-r-y slow application.
Posted : 02/06/2019 1:48 pm
