Hope hubs cross com...
[Closed] Hope hubs cross compatibility
8 Users
So, I have a hope pro 4 that I'm waiting for a new freehub to arrive for. It's possibly gonna to not arrive before my weekend ride. I also have a pro 2 hub. Can I use the pro 2 freehub on the pro 4? Or will I die a slow and painful death when the freehub dies in the middle of nowhere?!
Posted : 24/08/2018 1:38 pm
Pro 2 freehub is AFAIK a different width such as you can't fit an 11 speed cassette on it. So, yes, you'll die. Probably
Posted : 24/08/2018 1:55 pm
What if I'm running a 10speed on both hubs?
Posted : 24/08/2018 2:12 pm
Pro 2 doesn't fit Pro 4. I believe the drive rings are different sizes.
To be certain, go to the Hope website and check the part numbers on their exploded diagrams.
Posted : 24/08/2018 2:42 pm
not sure what you mean by the drive ring. I have looked at the hope exploded diagrams but the have very few dimensions
Posted : 24/08/2018 4:19 pm
Definitely not, the inner bearing and drive flange are a bigger diameter on the pro 4.
Posted : 24/08/2018 5:42 pm
They don't put dimensions on, but if they were the same parts, they'd carry the same part number.
Posted : 24/08/2018 5:50 pm
Pro 2 freehub is AFAIK a different width such as you can’t fit an 11 speed cassette on it.
Yes you can. I have a couple of PRO2's with 11 speed.
Pro2 and Pro4 are not interchangeable though.
Posted : 24/08/2018 6:31 pm
You can't fit a road 11 on a pro2 but you can use MTB 11.
In either case a pro4 won't fit a pro2, they're different diameters at the pawl end and the seal is a different size.
Posted : 25/08/2018 7:29 am
Yes you can. I have a couple of PRO2’s with 11 speed.
Interesting, which cassette are you using? I was considering going to 11spd on my cx bike but the hope website was pretty definite about pro2 Evo freehubs not taking 11spd
Posted : 25/08/2018 12:52 pm
I got a hope pro 2 pre evo and I got an 11 speed mtb cassette on fine.
Posted : 25/08/2018 1:53 pm
Shimano 11 speed mountain bike cassettes fit on a standard 8/9/10 speed freehub (largest cog is dished over) most road cassettes require a longer 11 speed freehub (everything has to fit inline).
Posted : 25/08/2018 2:26 pm
One has an XT 11-42 and the other a Sunrace 11-46.
Think they're talking about 11 speed road not MTB.
Posted : 25/08/2018 9:28 pm
Thanks, that's good to know. I'll stick with the 10 speed until my sti levers die then maybe look at an 11spd + hydraulic conversion
Posted : 25/08/2018 9:35 pm
