Hope hub problems!
[Closed] Hope hub problems!
7 Users
Just stripped a Hope Pro 2 rear hub.
Done it countless times but now I stumped!
Put New bearings in and xd body.
Freewheels fine out of bike but when In bike tight,freewheels forward and locks out backward?
What have I done wrong?
Small 3 mm washer behind freehub body as well!
Max
Posted : 14/04/2016 3:07 pm
you've put it in the drop outs upside down.
Posted : 14/04/2016 3:08 pm
pawls and springs in the wrong way round
Posted : 14/04/2016 3:13 pm
Yeah,
Checked pawls were round right way and they were same way as old freehub!
Thought Hope was playing some cruel joke!
Posted : 14/04/2016 3:28 pm
Ahh,
Cassette is locked in frame,not moving.
Max
Posted : 14/04/2016 3:35 pm
I'd go with spacers then.
Posted : 14/04/2016 3:41 pm
There is only one.
Just the 2mm one behind body.
Haven't touched the body as brand new.
Any others I mite have missed?
Posted : 14/04/2016 4:10 pm
Pro 2 or pro 2 evo?
Posted : 14/04/2016 4:21 pm
I had exactly the same thing.It's the end cap fouling the cassette.Even though hope only .list one 142 end cap I've got 2 slightly different ones (older pro2 evo)
A wee bit of dremel work and it works ok now.Had me stumped for a bit though.
Posted : 14/04/2016 4:29 pm
I had an end cap catching on the bearing when quick release was tightened.
Looked like the end cap had worn down a bit,washer behind end cap sorted.
I keep forgetting to get new end caps!
Posted : 14/04/2016 5:05 pm
Mine is a Pro 2 straight pull which I think is the same as the Evo.
I am running the old q/r end cap.
I know they provide a spare cap for 142 but this bike is q/r.
Which part of the cap do I need to dremel?
Thanks for the advice guys.
Max
Posted : 14/04/2016 8:51 pm
Put New bearings in
I would double check they're fully seated before letting loose with the dremmel.
Maybe double check with Hope, don't think xd drivers work with non Evo Pro 2
Posted : 14/04/2016 9:51 pm
Ended up buying new end cap from Hope.
Problem sorted!
My old one was breaking up and o ring kept falling out.
New one is slightly different but seems to have done the trick!
Thanks guys for advice.
Max
Posted : 21/04/2016 4:41 pm
