Hope Hub end Cap qu...
Hope Hub end Cap question.
3 Users
I'm stumped. Have Hope hubs running as boost - using end caps to make them boost. So .... if the wheels need to go back to 100/142 - does one just take caps off, or are different end caps required (which I clearly don't need or have lost). Basically wondering if I need to go and buy some end caps ...
Posted : 07/06/2022 3:15 pm
 nuke
You'll need end caps for whatever configuration you use so if you only have boost ones (reading it that you boosted non-boost hubs), you'll need new ones for 100/142
Posted : 07/06/2022 3:24 pm
Thanks Nuke - Chain Reaction here I come.
Posted : 07/06/2022 3:31 pm
You can get 'cheat' boost spacers for 142 hubs that are just 3mm thick spacers on each side. If those have been added then you can just remove them to make it 142, if you're got proper boost caps then you'll need new caps. There will probably be a spacer under the disk as well that needs to come out.
Posted : 07/06/2022 4:53 pm
