hope hoops (stupid ...
[Closed] hope hoops (stupid Question)
6 Users
currently with 9mm qr looking to change front to a 20mm front do i just use the adapters or is there more needed not with the bike at the moment
Posted : 02/07/2012 11:47 am
Just the adapters. It's a 2 minute job.
Posted : 02/07/2012 11:49 am
 nbt
You change the adapters in the wheel. That's it, for the wheel. You;ll have all the gubbins of swapping the forks, like swapping the brake and sorting the alignment etc
Posted : 02/07/2012 11:50 am
thanks guy's was hoping this was the case
Posted : 02/07/2012 11:54 am
Just looked there are two split rings with the adaptors are these needed if so where do they go
Posted : 05/07/2012 8:33 pm
There's a vid on the hope site.
Posted : 05/07/2012 8:37 pm
got some you can have for £8 inc pp
Posted : 05/07/2012 9:20 pm
 nbt
The hope bulb hub used split rings to hold the 20mm adapters in place, but the ProII hubs don't. You may have picked up the wrong adapters?
Posted : 06/07/2012 7:57 am
Pull the qr ones out. Put the new 20mm ones in & use a biro tip to push the split ring in place - pro2 evo btw
Posted : 06/07/2012 8:14 am
