Hope / GXP Conversi...
[Closed] Hope / GXP Conversion - any users out there?
8 Users
 Taff
I'm fed up of replacing my Sram bottom bracket every few months when the drive side bearing fails despite no end of maintenance to avoid any issues. I know hope stuff is generally pretty good on the longevity side of things but I haven't tried this set up before.
I think I'm going to go for a Hope steel b/b with the gxp conversion kit but want to know who has done this and how long your b/b has lasted so far in comparison to the Sram b/b.
Posted : 06/08/2014 1:05 pm
Yes, had a Hope BB fitted when the first GXP died within six months of infrequent use. The Hope BB is still going strong a few years on, now with Zee cranks after the Truvativ ones broke.
Posted : 06/08/2014 1:10 pm
Yep, 12 months in and no issues, the last one was from one of the early batched and still going. File a small groove into the push on fittings just in case you need to remove it though.
i used to have the hope BB with converters and a truvativ stylo crankset. ran it on 2 bikes for over a year with no issues, and so far subsequently have been using the same hope BB (well, one of them) on my current MTB with an XT crankset for 8 months, still going strong.
so yeah. it's been fine for me!
yep - 3 years, no problems
Posted : 06/08/2014 1:25 pm
Yep, but with ceramic bearings. Now over three years old, first 1.5 years were heavy use, the last 1.5 less heavy but on a single-speed that never gets cleaned. Bombproof, still running smoothly.
Posted : 06/08/2014 1:34 pm
All good here as well. I also did the trick with a couple of filed grooves as the inserts are pretty hard to get out without them.
Posted : 06/08/2014 1:36 pm
I'm sure I've got a set of hte inserts somewhere, never likely to use them, do you want me to see if I can track them down?
(reason being, I replaced my Truvativ cranks with Shimano, just made more sense. Especially since my cheap old XTR M970s weighed almost exactly the same as my X0 carbons 😛 )
Posted : 06/08/2014 1:52 pm
 Taff
All really positive responses so looks like this is the way to go. Many thanks for the responses.
Northwind - very kind of you, don't worry though. By the time postage and packaging is taken into account I may add well go mail order. Thank you though.
Posted : 06/08/2014 2:01 pm
 Taff
What do you mean by file a groove? is this to lever it out? Can you not drift them out?
Posted : 07/08/2014 3:09 pm
