Which hope pro 4 freehub would i need for running a sram nx 12sp cassette? Would it be the standard shimano 10/11 speed one?
All the googling in the world is not helping me answer this question...
Thanks in advance for all your help
It's a different free hub body for the sram cassettes to the shimano ones. Have a look in Hopes website, they normally have all the numbers on the tech drawings.
The xd one will run the more expensive gx etc sram cassettes which. The more budget sram ones have the standard shimano splined fitting.
However the shimano freehub hope offer say its 10/11 speed so i cannot work out if it is long enough to fit a 12sp cassette!
Normal 10-11spd freehub for nx eagle.. Son has one on a pro2 with no issues.
My pro4 has a small black spacer on the freehub so I can use an 11spd shimano cassette. Take it off if you want to use the 11spd road version
Yes standard Shimano 11 speed freehub for nx eagle , all Seam cassettes with a 10 smallest sprocket use the seam XD driver but the nx cassette is 11-50 ratio so runs on Shimano freehub.
Sram , bloody predictive text
You need the hope 536 freehub
Standard Shimano Freehub for SRAM NX.
Any of the other 12sp SRAM groupsets are XD
