How difficult are they to bend? I received mine in the post packed only in a jiffy bag, posted through the door onto a solid wood floor. Went to fit it tonight and there's a very noticable kink as it rotates. In fact so much that it rubs against the inner calliper when there's no pads installed.
It's the first time I've installed new rotors so could it be something wring with my fitting or just a duff rotor. Ta
Bent in the post, send it back for refund
wot he said that is a huge bend and damage in transit if new.
You cant fit then wrong to be warped assuming you have not put washers behind some of the bolts and not the others.
more trouble then they're worth them things! ime.
THanks for the info - Guess they'll be sent back then.
