Hope Evo Tech 3 Lev...
[Closed] Hope Evo Tech 3 Lever Pivot removal.
4 Users
I've got the circlip off but struggling to remove the pivot, it pushes out but buggered if i can get it to move!
Help please 🙂
Posted : 07/08/2016 7:45 pm
Mine needed some persuasion on one side. The bushing was pretty mangled and jamming up the pivot.
Posted : 07/08/2016 7:53 pm
Little grub screw on the inside of the lever, think there's some exploded diagrams on the Hope site.
Posted : 07/08/2016 8:09 pm
The grub screw is for the "Evo Tech cam pin" not the main lever pivot,
[url= http://www.hopetech.com/wp-content/uploads/2014/03/2014TECH3MCYLexplodedview.pdf ]Diagram[/url] so I pressume I just need to press or push it out somehow.
Thanks
Posted : 07/08/2016 8:20 pm
No, that grub screw has to be loosened to remove the lever pivot, look at the drawing it shows the groove in which the grub screw locates.
Sometimes they can be a little stiff so you may have to wiggle the lever up and down as you push it out.
Posted : 07/08/2016 8:48 pm
