Hope Evo crank spin...
Hope Evo crank spindle removal
5 Users
 drew
Hi, anybody know how to separate the axle spindle from the non drive side crank arm on a Hope Evo crankset? Cheers in anticipation.
Posted : 31/05/2022 10:05 pm
give hope a call, they're pretty good at picking up the phone
Posted : 01/06/2022 4:38 am
You need a part from hope and a press.
Part
https://activesport.co/epages/80c85f8f-7a95-4b1c-9c30-e64b314f3f2e.sf/?Locale=en_GB&ObjectPath=/Shops/80c85f8f-7a95-4b1c-9c30-e64b314f3f2e/Products/HC108-13TS&ViewAction=ViewProductViaPortal&gclid=EAIaIQobChMI-eLy59aL-AIVehoGAB0SSgenEAQYByABEgI5F_D_BwE
once the bolt is out you then need to press the old axle out and the new one in.
I took mine to a local engineering place to get them to press the axle out and in.
You might be able too bodge it, but why risk it on such expensive cranks.
Posted : 01/06/2022 8:02 am
 drew
Thanks for the replies. I have the tool but couldn’t see how to use it to remove the spindle and was wondering if I was missing something.
Posted : 01/06/2022 8:28 am
 drew
Thanks again for the replies. I phoned Hope this morning and spoke to Johnny in tech support who has sent detailed instructions on the official method and a quicker and simpler option using the original Hope crank installation tool so just need to get one of those now.
Posted : 01/06/2022 1:39 pm
@drew can you share how to remove the axle? The press fit between the axle and crank arm is making a very annoying creak when putting the power down on the non drive side crank. Hoping removing, greasing and refit would sort it.
Posted : 10/08/2022 4:53 pm
 drew
@sam1988 pm your email address and I’ll forward the instructions to you.
Posted : 10/08/2022 10:50 pm
