Hope District rack ...
[Closed] Hope District rack mounting; anyone managed it?
6 Users
The rack and bag combo that I bought for the commute completely obscures the seatpost and Hope don't make an alternative mount. Has anyone managed to figure out a neat solution to this?
Posted : 24/08/2015 8:48 am
What rack, bag and bike?
Posted : 24/08/2015 8:51 am
Topeak MTX rack & bag on a Cannondale Synapse. Not my setup, but like this:
Posted : 24/08/2015 9:02 am
Could you work something out with the existing light mount? Drill to take the bolts from the District mount, then place half a seat tube piece and part of a shim between the mount and the clamp?
Posted : 24/08/2015 9:11 am
from the thread title I thought this was going to be about reluctant doggers in the Peak. Is slightly disappoint.
Posted : 24/08/2015 10:09 am
Same problem, my solution is I'm planning to move to panniers for winter 🙂
I did see some photos of I think a topeak adaptor that clamped to a rack and gives you a cylindrical device to mount lights to. A bit like their handlebar extender.
SJS have a few adapters, this looks like the sort of thing http://www.sjscycles.co.uk/madison-universal-light-mounting-kit-for-madison-pannier-racks-prod26342/ but no mention of diameter.
Posted : 24/08/2015 10:27 am
The ctc forum has a solution
http://forum.ctc.org.uk/viewtopic.php?f=5&t=4902&p=34903&hilit=bracket#p34903
Posted : 24/08/2015 10:40 am
I have drilled the holes to take the clamp...forgetting that it's the plastic mount that activates the spring mechanism that holds the light in place! I did wonder about cutting the plastic mount but I'm not sure how I'd keep it in place [i]and[/i] have the confidence that it would stay in place during use.
Thanks, I'll have a look at those and see if they're suitable.
I don;t think that option is really suitable for the MTX due to the way the bag is designed to slide on & off the rack.
TBH, I was hoping for something a bit less Heath Robinson than a bodged option (I know some of you love a bodge!). I'm a bit disapointed that no one on STW has bothered to have a bespoke CNC mount made...
Posted : 25/08/2015 8:14 am
Hmmm, the Hope handlebar mount looks like it may offer an easier/neater bodge.
The bayonet part of the mount appears to be an all-in-one solution (so no separate plastic 'C clamp' required) and it's even removable from the main clamp.
I just need a way of reducing the main clamp diameter to 8-10mm, or, find a different clamp for the rack that'll take bayonet fitting.
Posted : 25/08/2015 8:32 am
If you cant work out how to bolt on that mount i suggest you step away and just buy a proper rack mounted light, such as...
[url= http://www.sjscycles.co.uk/images/products/medium/11880.jp g" target="_blank">http://www.sjscycles.co.uk/images/products/medium/11880.jp g"/> [/img][/url]
Posted : 25/08/2015 9:01 am
Tremendous, that hadn't occurred to me, I knew one of you guys would come up trumps 😀
Posted : 25/08/2015 10:47 am
Yeah but the district is 80 lumens of driver annoying brightness. 🙂
That puka rack light also has reflectors which is a bonus.
Posted : 25/08/2015 11:55 am
And auto on/off depending on brightness and movement, so no need to switch off.
One thing tho, those topeak racks dont have a proper light mount, but a nonstandard bracket and plastic adaptor for the light i suggested, so maybe not as ideal as first thought.
Posted : 25/08/2015 11:58 am
The District is 80 lumens of [i]daylight riding[/i] attention grabbing goodness!
I don't use it on full power when it's dark.
Posted : 25/08/2015 11:59 am
I tend to use mine on the strobe/triple pulse setting.
Not all topeak racks are the same either, I tried the plastc adaptor from my mtx beam rack and the holes didn't line up on my commuters topeak rack.
Posted : 25/08/2015 1:37 pm
If you are using the front light bayonet mount the helmet mount would be a better starting point than the handlebar one. It gives you a nice flat piece of plastic to either glue or screw to.
Posted : 25/08/2015 9:54 pm
A visit to a bike shop should net you an offcut of 31.8mm steerer tube (possibly in a choice of colours if you're lucky), and a couple of bottle cage/mudguard mounting spacers. Drill and tap the steerer to match the rack's light mount, file the spacers to match the steerer's profile, bolt them together using a spot of loctite,and use the 31.6mm adapter (0.2mm difference should hopefully be within it's capability) that came with the light.
Posted : 26/08/2015 6:16 am
