Hope Cassette Spaci...
[Closed] Hope Cassette Spacing..
5 Users
Afternoon all.
After swapping my cassette(road 10 speed) from my old wheel to a newly acquired Hope Pro III, I can't get rid of play in the block - despite everything being tight. All spacers are present and correct, but fitting another spacer to the inside of the lowest cog just forces the lock ring further out - meaning it cannot be tightened up.
Is there a specific spacer I'll need in order to get it to stay tight?
Many thanks
Posted : 13/06/2010 3:22 pm
There was a thread on this subject a few days ago. Do a search. I seem to remember talk of a half-thickness spacer.
Posted : 13/06/2010 3:29 pm
Did a search but couldn't find anything relevant..cheers though.
Posted : 13/06/2010 3:48 pm
Have you measured both freehubs to see what the difference in length is?
Posted : 13/06/2010 4:26 pm
You've got the 0.75mm 10 speed spacer behind the cassette yes?
Posted : 13/06/2010 5:14 pm
just sanding a spacer down now as the length is less than 1mm in the overall freehub length.
@ Njee nah, not heard/used one of those before! And that's with both Campag and Sram..Hmm.
Posted : 13/06/2010 5:18 pm
Dunno about SRAM, but Shimano 10 speed blocks are slightly narrower than 9 speed, so you need a spacer, sounds like that's your problem. Not required on Campag.
Posted : 13/06/2010 5:21 pm
Even though I've not needed a 0.75mm spacer on the previous two wheel sets I now do - is this just something to do with the Hope design I presume?
ta
Posted : 13/06/2010 5:24 pm
Made the spacer fit, still moves. Moral of the story: don't buy Hope hubs with alloy bodies.
Posted : 13/06/2010 6:37 pm
moral of the story - get the right spacer ...
nothing to do with hope
irrespective of the wheels you used before - shimano cassettes need that 0.75 spacer when used on any 9spd compatible hub - were your old wheels older shimano 10spd specific hubs ?
Posted : 13/06/2010 6:41 pm
I've put the spacer (0.75mm+/-) on - they still move. Yes, the old sets of wheels were Shimano 10speed specific.
Posted : 13/06/2010 6:50 pm
