Hope Brakes
[Closed] Hope Brakes
4 Users
I have a set of Mono M4's with Mini levers. Are the M4's compatible with more modern levers? Like the Tech3's?
Posted : 09/04/2022 7:59 pm
I asked Hope this very question.
They are.
Let me guess, lever blades knackered?
Posted : 09/04/2022 8:29 pm
No the levers are fine (although they do squeak for some reason) but I like the look of the Tech3's with the extra fiddly bits on them 😀
Posted : 09/04/2022 8:38 pm
 igm
And E4 pads fit M4 brakes. Give or take.
Posted : 09/04/2022 8:45 pm
Note the caliper is different though pad is the same. The older m4s had two piston sizes where newer brakes are both the same. Doubt this makes much difference.
However I imagine overall it may be cheaper to sell your current bushes and buy tech 3s.
Posted : 10/04/2022 7:54 am
Dunno about that, £89 each for the levers (in black) so £178 down vs £390 for two Tech 4 E4's and maybe £140 back if you're lucky leaving you £250 down.
If you want Tech 3 levers I'd get in quick though, it looks like they're being phased out (to no surprise).
Posted : 10/04/2022 10:21 am
