Hope Brake help
[Closed] Hope Brake help
6 Users
Just picked up a set of Hope M4 brakes (with Mini levers) off Facebook Marketplace. They have braided hoses and seem to be really well looked after. Gave them a service and fitted them but the only issue is they are a bit on or off compared to my old Deore brakes. Is this the braided hoses? Without changing the hose how can I get a bit more modulation into them?
Posted : 14/03/2022 8:08 am
What did you do as a "service"?
Posted : 14/03/2022 8:17 am
Full bleed and seal replacement
Posted : 14/03/2022 8:22 am
Braided hoses are just armoured on the outside, same spec hose as normal, you’ll not really do much for more modulation, maybe give the callipers a once over and rebleed to see if there’s any Stiction or oils a bit old?
I wouldn't think it is anything to do with the hoses.
I change my hoses to braided as these seem much more flexible than the standard black hose, and I can't tell any change in performance at all.
Posted : 14/03/2022 8:23 am
Maybe it's just down to the 4pots rather than twin pot I'm used to. Last time I used Hope brakes was when the Mono Mini's first came out. I had them for 3 weeks of squealing and changed them to Magura's 😀
I'll give them another once over and see how I get om.
Posted : 14/03/2022 8:34 am
It's not the hose. In fact, a while back Hope said there was no difference in their testing. That was when I changed back.
We're the pads replaced? If not, how old are they?
Posted : 14/03/2022 8:35 am
Pads might be something to change. I've not changed those yet. They look to have plenty of life in them. But I've no idea what compound they are.
Posted : 14/03/2022 8:42 am
Are they overfilled and almost solid as soon as the lever moves?
Posted : 14/03/2022 9:45 am
Good point Rick. That had also crossed my mind. I think I'm going to have to play around a little with the levels.
Posted : 14/03/2022 10:04 am
 JAG
Friction material.
As others have said, braided hoses have no impact upon brake performance.
Change the pads to something a little more progressive. There are no useful guidelines it's just 'suck-and-see' :o)
Posted : 14/03/2022 10:25 am
