Hope Bottom Bracket...
[Closed] Hope Bottom Bracket Bearing Tool - Will if fit shimano BB's?
3 Users
Anyone know if the Hope Bottom Bracket Bearing Tool will work on a shimano outboard BB cup?
Posted : 25/06/2014 10:31 am
If you mean the tool that tightens the cup into the frame then yes as it's a generic tool. I have a Hope BB and use a standard Park tools tool to tighten the cups. HTH
Posted : 25/06/2014 11:02 am
Possibly, the only problem I can foresee is the shimano bearings have a slightly larger ID than the hope bearings, so removal [i]might[/i] be a little more fiddly.
The OD of the bearings is the same, so installation should be ok.
Posted : 25/06/2014 11:52 am
Anyone own one, who could comment?
Internal diameter of the cup sleeve and external diameter of the bearing contact point (for removal) would be fantastic to know?
Posted : 25/06/2014 1:12 pm
