Anyone know the none hope part number?
Hang on a sec...
Right. Got one just in front of me waiting to go on my bike! 🙂
According to the little sheet in the box, the part number is: HS123
'None' Hope part number? Do you mean the IS code or whatever it is, like 60012RS for example?
Don't know that, sorry.
Is'nt it just a 1.5 bearing (hs135) and a reducer crown race (hs137)?
If not then hs123 is 1/8" bearing.
Which headset do you have; the 'standard' reducer headset (49.6mm headtube internal diameter) or the 'integrated' (55.9mm) one? Mine is the 49.6mm. Is HS123 the same as the 1 1/8" bearing? I dunno.
I was looking for the is code (or whatever) if anyone has it?
Thanks for the replys though.
It's the same size bearing as you find in a Cane Creek IS3 if that's any use. Or at least, I can't tell any difference and I've used them interchangably.
