'Hookless Tyres' fo...
'Hookless Tyres' for Vintage / Retro 'Hookless Rims'
2 Users
Afternoon folks
I'm trying (!) to help my Dad sort some new tyres. It's for an early 90's Falcon road bike with chromed, 'hookless' rims. Some 700c X 28mm tyres came off it.
We've done a fair amount of research but we still feel a little lost!
Does anyone here have any experience/s with such rim/tyre combinations? Re: sourcing new tyres... any advice regarding size (curiously, we've found several sources mention sizing down to a 27" tyre?!), width, makes/models, what to look for, pressures etc. will be gratefully received 🙏🏻
Many thanks, in advance.
Posted : 24/10/2022 4:25 pm
If 700c came off then that's what you'll need, either 27" or 700c could be "period", but they are different. Rim brakes possibly wouldn't have enough adjustment if a swap was made and I doubt that you'll be able to mix tyre and rim sizes (622 v 630mm)
You might hear that the C in 700c stands for "Crotched", i.e. hooked, it doesn't, it's a size
I ran a hookless rim and "normal" stock 700c tyre at 70psi on a tandem and it was fine, but that will vary from setup to setup so check with your LBS
Posted : 24/10/2022 6:15 pm
Thanks, @timba
So is it simply the air pressure pushing the tyre wall onto the rim that keeps a hookless tyre in place, given no 'cement'/glue is used?
Also, curious... when I've read of a 27" tyre being used, is the thinking that it's a tighter fit and thus more secure on the rim?
Any other thoughts/experiences from anyone? Any recommendations for a hookless tyre in 700c?
Thanks.
Posted : 25/10/2022 4:07 pm
