Hollowtech II Botto...
[Closed] Hollowtech II Bottom bracket?
11 Users
Hollowtech II bottom brackets. Is it worth paying a little extra for the XT or saint bottom brackets, or is the deore one ok?
I'm currently running a square taper XT bb and I plan a crankset swap over the christmas holidays.
Thanks.. 🙂
Posted : 06/12/2014 11:11 pm
Deore are really badly sealed. Ok for summer but I run Saint year round. Some will dismiss them but work for me (replace every 4 months or so)
Posted : 06/12/2014 11:13 pm
@tizzzzle-Replace every 4 months? Don't like the sound of that.. Do you not just change out the bearings?
Posted : 06/12/2014 11:17 pm
Go the extra IMO. The Gusset EXT24 BB is highly regarded by some on here. No experience of it myself but I have heard others giving it the thumbs up for reliability.
Do you not just change [s]out[/s] the bearings?
You can take the seals of (carefully) and flush the shit out with GT85 then force fresh grease in.
Posted : 06/12/2014 11:18 pm
I've gone through 2 deore's this year,not bad for £11 a pop really
Get a Chris king and never replace again!
Posted : 06/12/2014 11:24 pm
They are 15 quid a go, so no I just replace the whole shebang
Posted : 06/12/2014 11:29 pm
Erm, a Chirs Kings bb would be nice. Bit out of my price range..
Posted : 06/12/2014 11:30 pm
XTR seems to be worth the extra to me.
Posted : 06/12/2014 11:35 pm
I'm not convinced that XTR is any better than XT tbh, lifespan certainly comparable, if it's better it's not much better. XT well worth it over deore though imo, the lifespan/cost works out a little in XT's favour and it means less fannying about and less wastage.
But yeah, I'd recommend the Gusset EXT24- longer lived than Shimano, and fully rebuildable with standard bearings unlike Hope. And come in pretty colours 😉 The bearing life isn't amazing but it's a great balance of price, quality and lifespan
Posted : 06/12/2014 11:43 pm
XT will be OK, pop the seals off carefully and pack with grease when new to stop crap getting in them.
Posted : 07/12/2014 12:28 am
I'd stick with square taper if you can
Saint BB is currently £15, buy a few if you can afford it. You can regrease ^^ but (my Ultegra experience now) you can't easily get at both seals on the same bearing so cleaning thoroughly and regreasing is a faff
The Gusset is a bit dearer, and then factor in the cost of replacement bearings
Weigh up the cost of the three options
Posted : 07/12/2014 6:39 am
Uberbike BB IMO. Just as good as Hope and has lasted 4 times longer than my SLX. It is £35 mind but a good trade off between longevity and cost.
Posted : 07/12/2014 6:43 am
I got a Hope Stainless on one bike, have previously used an Uberbike one, the latter is cheaper and performed similarly.
Square taper on my other bike has seen more water and mud and still runs smoothly and has been hassle free. If you change, do it after the weather has dried up a bit!
Posted : 07/12/2014 9:31 am
Thanks for the suggestions. I think I'll leave it till spring for the swap.
I would stay with the square taper BB, but I was seduced by shiny new things 😀
I've seen videos showing how to swap out shimano bearings. Anyone done this?
Or is the gusset BB the best for serviceability and cost?
Posted : 07/12/2014 11:39 am
I swapped bearings on, iirc an XTR... Wasn't that hard, wasn't that easy. Shimano use a nonstandard, narrow bearing- there's ways around that but none of them are very elegant imo. I took the worst possible option and fitted Enduro's replacement bearing kit, which is absolute junk and lasted literally only a few rides before the bearings were rough and draggy.
I'd bet money Shimano design the BB shell to make it harder to remove the bearings tbh.
Posted : 07/12/2014 12:49 pm
