Highly padded mitts
[Closed] Highly padded mitts
3 Users
I'm after some highly padded mitts for the summer as I have a rigid SS which can be a little wearing on the hands when it's bone dry. Any recommendations (other than get some fromt suspension forks...)?
Posted : 03/06/2020 2:38 pm
personally
as a rigid singlespeeder.
I preser ESI grips in chunky with completely padless gloves. I find a thick mitt means I have to grab harder or the pads bunch up making its realy uncomfortable.
and tyre pressure/tyre choice can make a massive difference (more than a glove ever will)
Also found TOGS on the handlebar hep to relax the grip during the more mundane bits.
Posted : 03/06/2020 3:17 pm
Thanks. I've got grips similar to the ESI ones (Richey WCS) which work well. What pressures do you run up front?
Posted : 03/06/2020 3:35 pm
Those TOGS look useful too...
Posted : 03/06/2020 3:38 pm
I've had the WCS grips, they're not at all like ESI* TBH. ESI* are more like a tacky rubber foam, the WCS are more like a dry plastic/polymer foam.
I was a fan of the WCS grips for years, but ESI* really are a lot better.
I've got endura "aero gel" mits which have an solid ~3mm thick vented pad on the palm which works really well on the road bike. Not so great on flat bars through. I much preferred ESI grips and thin gloves.
I've been riding with my thumbs over the bars for years. Never got to the bottom of why but I get really bad joint pain in my thumb after riding rough stuff. TOGS might help, but TBH I happily just ride with my thumbs on the bar when climbing or cruising. I really wish someone (On-One) would make a modern swept back riser bar, like a fleegle, but 20mm wider and carbon)
*this is caveat-ed by the grips I gad might not have been ESI and were actually one of the cheaper brands like Vel, supercaz or XLC. I've also had some really cheap ones (£1.10) from china which were really good in the dry but slick when wet.
Posted : 03/06/2020 3:49 pm
I've used ESI in the past, both the standard and the chunky but they're expensive and I've found they're not that durable...
Posted : 03/06/2020 3:54 pm
Maybe mine weren't ESI then, I'm a serial destroyer of grips and bar tape, a mix of rough* hands and a tenancy to "throttle" the bars and they came on a bike, and I left them when I sold it ~2000 miles later.
Having said that, the current uberbike XL grips have worn the print off my palm in the last hundred miles!
Posted : 03/06/2020 4:02 pm
ESI are expensive i agree.
Personally not had durability issue but i have heard that criticism before.
TOGS aren't strictly necessary but they do allow a bit more security that the thumb over on their own. There are cheaper copies now i think. I really rate the concept though more than i thought i would.
Tyre pressures.. soft as i can get Away with without banging the rim.. AKA the thumb test
Posted : 03/06/2020 4:47 pm
