High(er) rise MTB s...
[Closed] High(er) rise MTB stem reccomendations please
4 Users
As per title:
(I believe) I need a higher rise stem for my bike.
I have some mid-rise bars, 5mm more spacer stack than rockshox reccomend and a tall fork for the frame already
Please Reccomend me something higher rise
(based on:)
[img] ?v=0[/img]
(Its not quite on level ground)
With:
mid-rise (25.4mm) EA70's (685mm)
105mm 6 degree (25.4mm) FSA XC-170 stem
(large size frame ~ 19"?)
and just because the other pic isn't very good (And has the other stem on)
[img] ?v=0[/img]
(its not on level ground in this pic either)
low-rise (25.4mm) EA70s (685mm) - since gone onto my hardtail which has I don't mind being low
90mm 6 degree (25.4mm) FSA XC-115 stem
With limited saddle drop as well(90mm with a chopped seatpost), its difficult to achieve a really good descending postion (unlike my hardtail), and when low makes it harder to pedal.
It climbs well with the 105mm, but I feel its still a bit too low unless its really steep
I've had a look at Thomson Elite 25.4mm 15 degree stems but in a 100mm, would only give 16mm more rise.
For £60 I ought to be able to get some EA50s and a specialized adjustable 31.8mm stem for that
What else is there? - I've not really looked for a 31.8mm high rise stem
Salsa do 40 degree stems too, but a 120mm version of those is effectively only 92mm length and 77mm of rise. I don't think I need quite that much
Not sure I like their looks either
Posted : 14/02/2009 5:26 pm
Come on, somebody must be have bought themselves a higher rise stem, what did you end up buying? and from where?
Posted : 14/02/2009 8:01 pm
Good question as I have been looking for one as well. Even harder for me as I need an oversize stem. Good Luck.
Posted : 15/02/2009 9:21 pm
wouldn't a thomson stem do the job perfectly?
Posted : 15/02/2009 9:25 pm
Hope do their stem in a 25 deg rise. Would that fit the bill?
I have a 70mm one and it's been as impressive as a stem can be. Dunno if they do longer ones in that rise, but you might want to check it out.
I think mine's too tall for my new bike and I'm going to go back to 10 deg rise though.
Posted : 15/02/2009 9:29 pm
After more looking around, it turns out bontrager do 25.4mm ones in 10 and 25 degrees of rise, but are 2-bolt (not 4) and look a bit pants:
Salsa also do 15 and 40 degree stems in 25.4 and 31.8mm sizes, but look arguably worse than the 25.4 bontrager ones:
[i]"Even harder for me as I need an oversize stem"[/i]
Bontrager do them in 17, 25 and 40 degrees in oversize
a 17 degree 31.8mm one looks alright
A thomson stem is only 15 degrees of rise, and costs a whopping £60. Wondering id theres anything for much less about
[i]"Hope do their stem in a 25 deg rise. Would that fit the bill"[/i]
Only available in 50 and 70mm, which is too short. They're almost £60 as well
Posted : 15/02/2009 9:47 pm
Check www.on-one.co.uk They have some 40 degree stem in now.
Posted : 17/02/2009 9:54 pm
