High speed interfac...
[Closed] High speed interface between handlebar and tree
5 Users
Brake lever is now very spongy, will a good bleed resume normal order or is it something more serious / expensive?
thanks
I am ok by the way
Posted : 14/03/2018 7:04 pm
If it pushed the lever in you may have popped a seal or over extended a piston on the caliper. So either a bit of fluid might have escaped or some air got in.
A bleed might sort it, or you might need to replace a piston seal.
Posted : 14/03/2018 7:20 pm
Maybe you need to try some wider bars.
Posted : 14/03/2018 9:06 pm
Blown a seal?
Posted : 14/03/2018 9:46 pm
Thanks all - a good bleed sorted it but alarmed to see the lovely pink Shimano fluid was a black sludge when push up from the Caliper end. No blubber involved.
handlebars reset and ready to ride again.
Posted : 15/03/2018 9:43 am
Thats why you need to replace fluids every year or two - wear particles and dust gets into it
Posted : 15/03/2018 10:38 am
