High rise bars - wh...
[Closed] High rise bars - what's out there?
20 Users
Sup.
I built up a bike for my sister who has issues with arthritis and says that the bars are putting excess weight on her hands as they are relatively flat.
It's a Pinnacle hybrid type bike and has something like 25mm rise mtb bars on it.
I've been looking around for something with a decent rise but not really gotten anywhere.
I'm not quite after ape-hangers but most stuff I've seen only goes up to about 35mm rise.
I'm thinking about 50mm upwards might be good to try and there are a couple of options I've seen out there but they tend to be upwards of £60 odd, which is a bit tasty for experimenting.
It's a standard 31.8mm clamp which I guess I could use shims in for maybe something like a bmx cruiser bar, but they're expensive too.
Other ones I've seen are 600mm wide or less which is a bit narrow I think probably.
So, anyone know of anything that might be worth trying that doesn't cost a packet?
Posted : 07/06/2021 11:19 am
You might be able to find a 25.4 stem and some easton ea70 (70mm rise) bars which IIRC are 680 wide.
Posted : 07/06/2021 11:26 am
Nukeproof bars come in 38mm rise, the carbon ones are very comfy (but over budget when not in the sale obvs).
You may be able to get a bit more rise with a stem swap as well?
burgtec have just launched a set of high rise 50 bars
Posted : 07/06/2021 11:27 am
Get an adjustable rise stem and stick with current bars. Sounds like it will be cheaper and she should be able to get the rise perfect.
Or planet x do a range of bars for the sort of thing you want.
Posted : 07/06/2021 11:36 am
Don't mess about with expensive bars to gain 25mm or so.
Embrace the ugly with a high rise adjustable stem or a steerer extender.
My guess is that she'd benefit much more from lifting things by 100 odd mm rather than 25.
Posted : 07/06/2021 11:44 am
I got some Spank 31.8 60mm rise bars from Chain Reaction recently, they're only £35 or so. Or embrace the ugly and get an Adjust-O-Stem (we've got one on the tandem and it's both brill and hideous in equal measure 🤣 )
Posted : 07/06/2021 12:14 pm
This.
Posted : 07/06/2021 12:33 pm
Ah cheers. Hadn't really considered the stem, largely because they tend to be quite long. I'm thinking any benefit in rise might be lost a bit in being very long... 🤔
Posted : 07/06/2021 12:36 pm
50mm rise here: https://www.bricklanebikes.co.uk/blb-big-g-bar
Both rise to and weigh as much as the moon
Posted : 07/06/2021 12:41 pm
A friend of mine had an accident a few years ago where he broke both his elbows in a nasty off, one of them seriously. Its a permanent injury that means he effectively cant do press ups so to get him out riding again I had to consider this.
I fitted a slightly shorter stem with a little rise, only about 5 degrees and fitted some On one Mary bars and Ergon grips. Turned his head down arse up Kona PhD into a gentleman's commuter and he is happy riding again.
https://www.planetx.co.uk/i/q/HBOOMA/on-one-mary-handlebar
Posted : 07/06/2021 12:49 pm
Brand-X Trekking bars, worth a try at £15.99. I have them on my and my daughter's sit-up-and-beg commuter bikes, and like them. They look a bit daft, mind.
Posted : 07/06/2021 12:50 pm
Try Amazon for cheap 50mm rise bars
Posted : 07/06/2021 12:56 pm
The answer to this is so simple:
https://www.amazon.co.uk/Lixada-Aluminum-Handlebar-Mountain-Cycling/dp/B07B9TQHMV/ref=pd_sbs_1/258-0506929-1395621?pd_rd_w=eQEnN&pf_rd_p=1469375b-13b4-495f-86c1-e268482be980&pf_rd_r=6X7XRPRC7AXXA4TDNGZ6&pd_rd_r=22a47b1b-5354-45e5-b72c-1b6167bb9d93&pd_rd_wg=22HyC&pd_rd_i=B07B9TQHMV&psc=1
My wife has something very similar. Raises the bars 50-60mm or so, and has a forward reach of about 80mm. Transforms the handling of the bike, much more upright position.
Posted : 07/06/2021 1:06 pm
Or have a word with Jeremy Corbyn and see where he got this set-up?
Posted : 07/06/2021 1:41 pm
Stem riser AND a high-rise adjustable stem! All the options in one attractive package! What's not to like? 😀
Posted : 07/06/2021 1:48 pm
Soma Dream Riser bar.
https://southerndistributors.co.uk/product/soma-dream-riser/
Posted : 07/06/2021 9:04 pm
https://www.planetx.co.uk/i/q/STOOGN/on-one-goose-neck-stem
Planet X gooseneck/limp dick stem. Would look extra weird with riser bars!
Posted : 07/06/2021 9:15 pm
Thanks but way too expensive.
I've found an 'XLC riser bar' for 15 notes I'm going to try. It's a 50mm rise so should help.
Might look at a riser stem if more is needed.
Thanks folks 👍
Posted : 07/06/2021 9:20 pm
Bmx Stem and 7/8 single wall moto-X bars with a detachable brace always does it for me. Mind you, it will weigh about a kilo.
The factor with hand issues and a number of MTB high rise "lesser-branded" bars I've found recently could be the sweep/upreach angles. I've seen some 10-11deg/5deg (upreach/sweep) bars that are just plain uncomfortable. But by really reading the specs of various moto-X bars you can find a 8deg/4deg bar to be more comfortable in use.
Posted : 08/06/2021 10:54 am
CRC just got some stock in. I bought some Spank Spoon bars. They got 60 and 75mm rise. I got the 75mm
Posted : 12/06/2021 2:35 pm
Interesting topic, my brothers gf is moaning about the front end being low despite a shite load of spacers, high rise bar and a stem with rise in it, I advised getting a 20mm longer fork but those 60 or 75 rise bars could be the answer but would probably look as mental as that stem above.
Posted : 12/06/2021 3:27 pm
 LAT
https://www.ergotec.de/en/
these guys will have something
Posted : 12/06/2021 8:14 pm
