Hi-mount or lo-moun...
[Closed] Hi-mount or lo-mount front mech?
7 Users
I wanna get a new front mech, looking at an SLX one, seems to come in several flavours. I need a top or dual pull one, but can't decide on a hi-clamp or low-clamp one.
There's no bottle bosses or pivots or anything to get in the way so either will fit, I just wondered if there was any advantages (perhaps better stiffness and shifting due to the wider pivot spacing?) of the low-clamp over the more "traditional" design of the hi-clamp.
Posted : 29/06/2010 4:26 pm
higher clamp conventional ones seem to last infinately longer IME, they dont develop play and dont clog with mud anywher near as quick.
I use an old 8 speed LX one becasue it won't die, I've killed 5 or 6 of the newer style ones before i dug this out of the spares box in desperation, its worked flawlessly ever since.
Posted : 29/06/2010 4:29 pm
agree with thisisnotaspoon
hi clamps do not die ever....
paul
Posted : 29/06/2010 4:58 pm
I am building up a 14" Trek frame and the cable holder on the seat tube is pointing the cable down & towards the non-drive side so I need a low clamp one to keep the cable running straight out of the outer.It would be a real sharp turn to get the cable on to a high clamp due in part to the close proximity of the components(short seat tube)
On my 16" Handsome dog I have a high clamp SRAM unit but looking at it it looks like it should have been a low clamp but the angle is not quite so acute due to the extra length of seat tube &/or the cable holder angle.
Posted : 29/06/2010 5:28 pm
high clamp for all the same reasons as above + they work better and have less 'wasted' metal & plastic than the horrible dog turd attracting low clampers
Posted : 29/06/2010 6:19 pm
+1 for high clamp if it fits - however they can fowl bottle cage mounts 🙂
Posted : 29/06/2010 6:29 pm
yep, if the frame will take it, conventional swing last a lot longer
Posted : 29/06/2010 6:30 pm
That's pretty conclusive! Conventional swing it is then.
Posted : 29/06/2010 9:39 pm
