Help with Mavic rim...
[Closed] Help with Mavic rim please
6 Users
 Mr5O
Help
I have just tried removing one of the eyelets from my Mavic xm 819 rim and it has sheared leaving most of the threaded section in the rim. Any tips on how to remove it????
Posted : 07/11/2011 9:05 pm
 Bez
Hm? You mean the nipple? Eyelets aren't threaded (why would you remove an eyelet?) When you say you tried removing whatever it was, what were you doing?
Posted : 07/11/2011 9:11 pm
Ignore Bez.....
They are left hand thread so you could wind in a self taper or bolt as an eayout maybe?Try pouring boiling water over it to help (different expansion rate before antone asks).
Posted : 07/11/2011 9:15 pm
 Bez
Ok, just googled - sorry. Those eyelets don't look like any eyelets I've ever seen... tubeless rim I guess?
Who'da thunk there was even more fun to be had with tubeless? 🙂
Posted : 07/11/2011 9:17 pm
 mboy
Kettle of boiling water, pliers, a self tapping screw etc... Have all on hand as Rorscarch says.
Whoever built it, if they built it properly, will have thread locked them in so they should be reluctant to come out at least. Just depends whether the thread lock they used was a nice Loctite blue, or have they used superglue (as has been heard of!)...
Posted : 07/11/2011 9:20 pm
 Mr5O
Left hand thread, that would be where I went wrong then, bugger
Posted : 07/11/2011 9:21 pm
 mmb
tubeless rims do use threaded eyelets and the mavic 819 is a tubeless rim bez.
mr 5 0 you need to locate a screw extractor set, these are used to remove bolts etc that have had the head rounded or sheared off. they use a reverse thread. try your local hardware store.
http://uk.rs-online.com/web/p/screw-extractor-or-sets/4609516/ you'll also need the handle from a tapping set to hold the screw extractor while you remove the eyelet.
Posted : 07/11/2011 9:24 pm
 Bez
Yeah, I am edumacted now. The reward for my ignorance above is that I can use this new knowledge to further scoff at the crazy world of tubelessness 🙂
Posted : 07/11/2011 9:28 pm
 mmb
he-he fair enough! 😀
Posted : 07/11/2011 9:37 pm
How are they going to work on a LH thread? Surely a self tapping screw would be a better idea?
Posted : 07/11/2011 9:39 pm
