Help with Garmin Ed...
[Closed] Help with Garmin Edge 520 and Strava Live Segments
8 Users
I cant for the life of me get this to work and it is making me very angry.....
I have been out for a ride with the 520 and uploaded the activity to Strava via Garmin Connect without any problem. I have also created Strava segments which are showing in the 'created segments' tab on Strava.
However when I then disconnect my 520 and go to the device and look for segments, there are no segments saved.
Am I missing something?
Thanks for your help.
Posted : 14/09/2015 3:10 pm
You need to "favourite" the segments via Strava, click on the little star. You don't need to have created them yourself.
You need to be a premium Strava member too.
Posted : 14/09/2015 3:16 pm
Thanks Njee
I have already starred them and I do have a premium membership.
Seems like there is a step missing where I transfer them to the device?
Thanks for your help its driving me mad!
Posted : 14/09/2015 3:24 pm
Once starred they sync automatically when you sync your device. I do mine over Bluetooth using my phone.
Posted : 14/09/2015 3:57 pm
Yep, without wifi on the device you have to pair with your phone. I'd expect it to do it when you plug it in though. I've got a 1000, so not an issue 😉
Posted : 14/09/2015 4:01 pm
You need to make sure that your Strava account is linked appropriately with your Garmin Connect account. When I had a similar problem to you I had to do another log-in to strava from GC, creating a strava segments tile on my GC homepage. This was despite my having used GC to upload to strava for months beforehand.
Posted : 14/09/2015 4:18 pm
Stevious - sounds like thats the issue, do you remember where you got the walkthrough from to do this?
Thanks
Posted : 14/09/2015 4:21 pm
Sorry, I just faffed about until it worked. Wasn't hard though, I think I just added a new panel (or used an existing one) to the homepage of GC.
Posted : 14/09/2015 4:35 pm
Doesn't Garmin express try to link to strava? Also make sure its synch'd.
Posted : 14/09/2015 4:47 pm
Finally got it sorted - thought I would share in case anyone has the same problem.
Even if you have already linked strava with garmin connect in some cases you need to unlink and re-link them before syncing with a new device.
The live segments should then appear in garmin connect for transfer to the device.
Hope that helps someone next time.
Posted : 14/09/2015 8:02 pm
How many starred segments can you install on the 520?
Posted : 14/09/2015 8:47 pm
Loads
The problem so far is turning the sods off. On a longish run I don't want to be told about segments, on some short runs locally then maybe
Or turn the tunes off...driving me nuts
Posted : 14/09/2015 8:58 pm
Fair point- you can disable them if you don't want some or all of them coming up on a particular ride, but there is an element of ballache to it.....
Posted : 14/09/2015 9:02 pm
Bloody thing ! I must have atleast 150 but only about 60 has sync'd ... I've even unlinked and relinked 😐
Posted : 14/09/2015 9:09 pm
Holy thread resurrection! I canny seem to get the strava segments on there either, both accounts linked, segments started... Come on!!!
Posted : 05/03/2016 7:06 pm
Starred, not started.
Posted : 06/03/2016 3:22 pm
