Help with fitting K...
[Closed] Help with fitting Kuota Crank set
1 Users
Hi all
I'm obviously doing something wrong when fitting a carbon Kuota K30 crank set.
The cranks seem to be working loose over 20 odd miles - the drive side is then drifting out along with the bearing.
I tighten the bolt through the shaft so that the cranks spin freely - 1/4 of a turn more and they go tight, so assume they're too tight against the frame.
Any ideas what I'm doing wrong?
Ta muchly 😀
Posted : 08/10/2014 8:34 am
