help to measure Rea...
[Closed] help to measure Rear shock change
4 Users
I'm thinking of changing my sick fox triad rear shock off a 2011 Camber expert for genuin fox, broken second time in two years. but unsure how measure the stroke, the lenth is eye to eye. anyone help please
Posted : 03/04/2013 2:16 pm
51mm stroke from the look of it.
Posted : 03/04/2013 2:30 pm
Surely you just let all the air out and compress it to the stop?
Posted : 03/04/2013 2:36 pm
I make it 200mm lenght and 55mm stroke if iv'e measured it rite. I can find one but it's only 51 stroke, thanks so far.
Posted : 03/04/2013 2:48 pm
A 200x51 and a 200x55 are the same length, (200mm 😀 ) the 51mm stroke version has a limiter on the shaft (inside, not visible) to reduce the stroke, according to the chart up there ^^^ yours is a 51mm stroke, if you get a 55mm one it will compress too much and possibly damage your frame..
Posted : 03/04/2013 2:55 pm
