Help sizing Special...
[Closed] Help sizing Specialized MTB
7 Users
I have just ordered a Specialized Chisel Comp Xl and wondered if anyone had advice about sizing. I am 185cm and suggests I am borderline L/XL. I used to have an old specialised hard rock in 2005 and was Xl but does anyone know if geometry has changed much? Will get to test ride in a month but wanted some advice if anyone else fits between sizes.
Posted : 12/02/2021 7:48 pm
I had previous 2019 model in large, I’m 5’10”. Spot on. Borrowed a mates medium, too small. Hope that helps?
Posted : 12/02/2021 8:20 pm
Have a look on geometrygeeks and compare it with your current/previous bike. I'm also 185 and have had two large specialized cambers (2014 and 2016). With hindsight I should have considered XL but they worked for me at the time.
Posted : 12/02/2021 10:43 pm
Massively. The top tube won’t be as high on today’s geo but it’ll be a longer reach to the bars. Amongst other differences.
At that height I’d say XL but what do Spesh recommend? Don’t avoid XL because of a bad experience from 2005.
Posted : 13/02/2021 8:14 am
The spesh size charts say Large but the reach of 450 looks short on it to me. They also say it comes down to preference as I’m borderline.
Posted : 13/02/2021 9:16 am
176cm here and on a large Levo SL. Fits perfectly.
Posted : 13/02/2021 9:34 am
Geometry has changed massively, modern bikes are generally quite a lot longer than older bikes. Descriptions like L and XL don't really mean much. I've seen S, M, and L sized bikes with ETT lengths that are pretty much the same. Your overall height isn't always a good guide either because body proportions can vary quite a bit. Personally, I much prefer a bike that is slightly too small than too large. Other people seem to prefer the opposite.
Posted : 13/02/2021 10:40 am
Thanks reckon the XL may be fine but I’m allowed to test ride before so that’s ok.
Posted : 13/02/2021 2:37 pm
most companies, specialized particulalry, run stems that are always too long on their frames i find.
go size larger and shorten sten.
Posted : 13/02/2021 11:42 pm
