Help… Scott/ DT Swi...
[Closed] Help… Scott/ DT Swiss Nude 2 shock replacement
3 Users
Hi Folks
After many years of good service my Nude 2 has given up the ghost. It’s been in for a service and it has had it,
Fitted to a Scoot Spark RC which I would still like to use. Can they be replaced? If not what is a good replacement?
Thanks
Posted : 07/01/2022 2:34 pm
Impressive life span!
26 or 29?
26 was 190x50
29 was 165x38
Scott moved to fox on that same generation frame so there might be some take offs floating about.
Posted : 07/01/2022 4:01 pm
Hi..
26” Spark RC
I don’t think it’s worth shelling out £500… I might have to look at an alternative and live without the remote lockout 😢😩😢
Posted : 07/01/2022 4:50 pm
Hi
Would Fox Nude shock off a 2016 Genius work on my Scott TC 2013
Thanks
Posted : 10/01/2022 2:11 pm
Nope, too long. genius was 200x55. You need 190x50 per the above measurements.
190x45 is more common if you're okay loosing 10-20mm rear travel and the tracloc functionality.
Posted : 10/01/2022 5:42 pm
Thanks
Posted : 11/01/2022 12:42 pm
Can you just fit a cheap 2nd hand RP23 or RP3 shock and not have the lockout? Or a similar sized R/S shock.
Posted : 11/01/2022 4:00 pm
