Help! Park automati...
[Closed] Help! Park automatic valve selector stuck on schrader
6 Users
As above the automatically valve selecting head of my park tools pump is stuck on the schrader side - if I put a presta valve into the other hole it just keeps blowing out through the schrader side
Anyobe know how to remedy this or is it now dead?
TIA
Posted : 14/04/2018 4:23 pm
My Blackburn won’t swop over if there is no back pressure
Posted : 14/04/2018 4:28 pm
Not on a Park pump but my floor pump does that if I use the schrader side, I have to take the head apart & put it back together & all is well in the world until I next use the schrader <shrug>
Posted : 14/04/2018 4:35 pm
If it's similar to our INF1 from Park, it's usually caused by the seals and shuttle getting gummed up. Remove the caps and seals, clean them, lube them with silicone, re-assemble, and they usually work fine until they eventually gum up again.
Posted : 14/04/2018 6:09 pm
wot jam bo said about back pressure - it's a pain in the arse
Posted : 14/04/2018 6:15 pm
it’s a pain in the arse
You're definitely using that pump the wrong way...
Posted : 15/04/2018 10:06 am
