Help needed - GXP 2...
[Closed] Help needed - GXP 2 crank removal
3 Users
am trying to remove cranks, have removed the 10mm and 8mm screws and the washer...at this point i thought the non drive arm would just fall off, then the drive side and spindle would slide out
but the ND side is solid and not budging
HELP!
Posted : 15/08/2012 6:52 pm
screw them back on, then back the 8mm off this will use the 10mm as a puller.
Posted : 15/08/2012 7:05 pm
GLAD I WASNT BEING MEGA STUPID - THANKYOU BOTH!
Posted : 15/08/2012 7:13 pm
