He's got a 2008 Stumpjumper with a 120mm Spesh shock, (no markings to give an idea of which one) It's knackered, even Bike Scene can't fix it (no parts available)
A new shock is £220 from CRC but I'm hoping someone on here can come up with a suitable 2nd hand one maybe. Not sure of the dimensions at the moment either.
The only alternative is to buy a new bike but he's skintrupt.
Hope someone can help/advise!
What dimensions are the shock off CRC that costs £220?
According to [url= http://www.bikepedia.com/QuickBike/BikeSpecs.aspx?year=2008&brand=Specialized&model=Stumpjumper+FSR+Comp ]bikepedia[/url] it's a "Fox Triad custom for FSR, 120mm travel". Some sort of RP23 will likely match.
what he said you need to know
eye to it - or the length of the chock
You then need to know the length of the travel
Eg
190 mm long
51 mm travel/stroke length
I think thats an Orange 5 measure FWIW
what ever it is It'll be a custom length with a custom travel, good luck finding out as it looks like spesh have given up providing support for older models (the link to the manual for 2008 comp model was broken for me).
some other threads suggest it's 7.25x1.75(184x44) and fox made a rp23 in that size in 2010 whether they still do.
Cheers fellas, I think he's following this now. Might be an idea if he gave Mojo a call?
I'm sure I've read somewhere before that the best replacement is a 190mm i2i shock ... anyway CRC have ex-demo RP2 190 i2i 55 stroke for £150, or ebay will have a few this size.
I am pretty sure that the problem is with the 3 way swing on these and Mojo can do away with this and leave it on pro pedal. This is what I ride with all the time anyway. Dunno if that is helpful for you.
I dont know the exact model your son has but the Specialized Stumpjumper Comp/elite 2008 shock length is 7.250 x 1.750 (184 x 44)
Shaft hardware kit serial number - 803-03-130 Fox shock
Body hardware kit serial number - 803-00-119 Fox shock
should be able to find one on ebay I suppose.
Try spec UK? My 2007 stumpy fsr brain shock died last year and was as cheap to get new one off shelf than sort it - so they may have some lying about?
Bin it and go 190x50mm. My old FSR came this way. I then went 200x57mm with offset bushes. Worked fine and loads moar travel.
Some good stuff been suggested & he's very grateful, Cheers chaps.
I have an old manitou 3 way somewhere. Came off a 2006 orange 5. If I can find it(I'll check tomorrow ) if he wants it he can have it FOC.
I went 190 * 50 on my last Stumpy (of that era). Worked great.
I have a 200 x 50 x fusion r2 he can have if he wants . might not fit but good to keep the young shredders shredding
Skink & Howsyourdad... you are true gents!
He's 28 though so not so young. Still skint like me though. 😥
6 years younger than me so I guess it counts !
Cheers Gonzy, I'll pass that on to him!
