Help - my bike keep...
[Closed] Help - my bike keeps going 'click'
8 Users
if I put my weight on the pedal with the leading cranks arm at 2 o'clock.
it clicks once when you load it and once when you unload. doesn't seem to matter which chainring it's in - it's a certain amount of torque through the crank arms that causes it.
it's a Giant NRS. I've tried it with the shock 'deflated' and it does the same with the suspension bottomed out.
so far I have;
tried a different rear wheel
checked the ring bolts
checked the chain
taken the cranks out and checked the BB/reassembled
let all the air out of the shock and checked the suspension isn't noisy/creaky.
checked the suspension bolts are torqued up
I'm running out of ideas but the bike's unrideable (for me) - it's just so annoying that you get this click everytime you stand up on a hill or put some torque through it on the big ring.
Posted : 29/06/2010 1:09 pm
Back wheel off. Bit of grease around the dropouts and the axle. Wheel back in. Done.
Has happened to me on a couple of bikes. The QR moves slightly under load
Posted : 29/06/2010 1:14 pm
Take the front mech off (sorry) clean clamp and frame thoroughly, ressemble. Cross fingers.
Posted : 29/06/2010 1:15 pm
check your pedals? double checked all the suspension bushings and bearings?
Posted : 29/06/2010 1:17 pm
Pivots possibly.I had & did the same as you only cured it Friday. For some reason I had play in the pivot even though I'd put new bearings in.I added a1 mm washer job done.
bigyinn - not sure how the front mech coudl be to blame - there's nothing touching it when I pedal?
I guess I could dismantle all the suspension and reassemble/retourque.
will try and grease around the drop outs and put some different pedals on.
the 'click' really resonates through the frame.
Posted : 29/06/2010 1:22 pm
My money is on regreasing pedal threads.
Posted : 29/06/2010 1:23 pm
right, just changed the pedals (newly greased threads) and took the back wheel out and greased around the axle/dropout.
still got a click 🙁
might try another BB with a bit of ptfe on the threads before I start taking the frame apart.
Posted : 29/06/2010 1:36 pm
It's cracked I reckon 🙁
Posted : 29/06/2010 1:40 pm
I did have a look at the welds a minute ago as I suddenly thought 'I wonder?'. Couldn't see anything obvious but it's not the best lit garage in the world so I may have a closer look with a torch later.
Posted : 29/06/2010 1:43 pm
Bright daylight is quite useful for seeing things clearly!
Posted : 29/06/2010 2:04 pm
no cracks found.
BB then suspension I think...
Posted : 29/06/2010 3:07 pm
I had a very similar noise coming from my Bb/chainset area recently...tried everything to no avail. Eventually decided to live with it...then came down Helvellyn a couple of weeks ago and Hey Presto! no noise any more....So theres your answer...Fly down a big hill with lots of rocks...!! 😉
Posted : 29/06/2010 3:50 pm
If it carries on clicking it's likely to get chucked down a big hill with lots of rocks!
Posted : 29/06/2010 3:53 pm
replaced bottom bracket and silence reigns.
old one was quite 'dry' on the threads but bearings seemed fine so not sure whther it was the BB itself or BB/frame interface.
Still, I can ride without sounding like I have a castenet in each knee now 🙂
Posted : 01/07/2010 12:33 pm
