Help me Identify Th...
[Closed] Help me Identify These Forks and Brakes (MTB)
4 Users
Took these forks and brakes off of a second hand build I recently bought as I only needed the other parts, but I have no idea what 'model' they are but would like to sell them...
Forks are Manitou. 80-100mm travel, adjustable by turning the red dial on the bottom of the fork leg as pictured. They have mounts for both disc and v-brakes. Not sure if the tribal graphic was on there as standard, but I would assume the previous owner put it on thinking it looked cool. They have the arch behind the fork legs as opposed to the more common being in front. Standard 9mm quick release and non-taper steerer.
Brakes are Hope hydraulic disks. IS mount, although front has adaptor in the picture for post mount. Pads are square with a single pin through the top middle to hold them in.
Posted : 08/12/2012 6:33 pm
mono mini
manitou black elite
Posted : 08/12/2012 6:35 pm
sorry its a hope mini not mono mini.
Posted : 08/12/2012 6:36 pm
 v10
Manitou Black Elite and Original Hope Minis
Posted : 08/12/2012 6:37 pm
Forks are Manitou Black Elite (and the tribal graphic was standard) - not sure of the year but a google image search seems to suggest that some models had the adjustment on the top of the fork leg and some at the bottom so shouldn't be too difficult to work out. Brake I think is the original Hope Mini (as opposed to the Mono Mini).
Posted : 08/12/2012 6:38 pm
